Romes Posted July 21, 2015 Report Share Posted July 21, 2015 Basically I have a lot of fully painted bases on my daemons that look like this: http://shop.microartstudio.com/possessed-bases-25x25mm-5-p-862.html They're a pretty solid resin. Because they are solid, and don't have elevated edges like GW bases, I'm wondering if there is a way I can trim down the corners to turn a 25 mil square into a 25 mil round. I know this will do some damage. I've drilled holes in them with a dremmel before, but never cut the material. Anyone have any suggestions on a tool that could do a curved cut on these? Quote Link to comment Share on other sites More sharing options...
pretre Posted July 21, 2015 Report Share Posted July 21, 2015 Make sure you wear a mask. Quote Link to comment Share on other sites More sharing options...
Romes Posted July 21, 2015 Author Report Share Posted July 21, 2015 Yeah thanks that's a good call. Quote Link to comment Share on other sites More sharing options...
ClassicFlava Posted July 21, 2015 Report Share Posted July 21, 2015 I wonder if you could use the drill bit that is a cylinder. I forget what they are actually called. Just a thought Quote Link to comment Share on other sites More sharing options...
PourSpelur Posted July 21, 2015 Report Share Posted July 21, 2015 Remember that hole bits are measured by outside diameter and you want a 25mm inside diameter. Personally, I'd grab a plain 25mm base and take it to Home Depot. Stick it inside the bits until you find a good fit. Quote Link to comment Share on other sites More sharing options...
Threejacks Posted July 21, 2015 Report Share Posted July 21, 2015 I wonder if you could use the drill bit that is a cylinder. I forget what they are actually called. Just a thought Metric Hole Saw,though getting it started without the center drill bit is not only very hard to do but rather dangerous , it would likely run off on you and wreck the others on the piece. I would probably mask up and use a medium grit wheel on my bench grinder after marking out the circle on the back of them.Would need to cut out the squares first and just go slowly shaving off the corners then finish up to the circle lines,you could probably put a fairly decent looking bevel on them too. Easy for me to say though as I used to be a tool and cutter grinder,heh. Quote Link to comment Share on other sites More sharing options...
ClassicFlava Posted July 21, 2015 Report Share Posted July 21, 2015 Well yeah I would secure the base down before drilling it Quote Link to comment Share on other sites More sharing options...
thatdave Posted July 21, 2015 Report Share Posted July 21, 2015 If you have access to one I'd recommend using a scroll saw. It's for finer wood working and the blades are small. Quote Link to comment Share on other sites More sharing options...
savion47 Posted July 22, 2015 Report Share Posted July 22, 2015 Moved to artificier's forge Quote Link to comment Share on other sites More sharing options...
InfestedKerrigan Posted July 22, 2015 Report Share Posted July 22, 2015 I'd use Instamold to make a green stuff copy of the bases, cut the green stuff down to size on the 25mm base, and then make casts of the round base. Quote Link to comment Share on other sites More sharing options...
Romes Posted July 22, 2015 Author Report Share Posted July 22, 2015 Thanks for the suggestions all! Will post here when I try something out. Quote Link to comment Share on other sites More sharing options...
Guest Posted July 22, 2015 Report Share Posted July 22, 2015 A while back (4th, or early 5th ed 40k), got some Hirst Arts tiles for my 40k Witch Hunters. The pattern I decided on was square, so I glued the square textured bit to a round base. Opponents did not complain at all. It looked nice and was really easy to apply. 40k opponents won't care if you are textured squares mounted on round bases. Heck, 40k rules say to use the base the model came with, so no need to even switch to round bases. I can't imagine that new WHFB actually has rules forcing the base switch, as that just isn't GW's style. Quote Link to comment Share on other sites More sharing options...
